Old 03-19-2014, 09:53 PM   #75 (permalink)
Teri_TX
Hi Pete,
Originally Posted by Ironside View Post
Found this while searching
MOTORCYCLE BIKER HELMET STICK ON SPIKE STRIP MOHAWK LONG CENTER SPIKE | eBay
should frighten the jaywalkers.
I love it! Stall strips for helmets!
Thanks Teri, I've found suppliers of T section trim and D section conduit that will do the job, also stick on chrome trim which could be used without painting, all available for pennies. I was a scientist in a previous life, so a little experimenting is in order I think.
"D section conduit"? Is that for the add on surface wiring when the power wiring in a building isn't readily accessable?
Also I must thank you for starting this thread, it came at a very opportune moment for me.
Regards
Pete.
You're welcome!
Regards,
Teri
