Old 03-20-2014, 02:53 AM   #3 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Originally Posted by iveyjh View Post
My UltraGauge does the same thing.
Is it the same readout of 0-125? The SG also has codes to enter that are listed as A/F Ratio Sensor 1 Bank 1, but when I enter those in no data shows up. Honda must not display that data, which is a shame because the actual A/F ratio readout would be more helpful than just the voltage.
Do you have similar experiences with lean burn conditions? I was a little worried at first because I have a cheap(er) O2 sensor. It game me codes and trouble until I figured out my non-OEM exhaust manifold was the problem. Switched back to an OEM setup and LB started working again, codes gone. The only thing now is that my EGR valve is broken. I actually have the connector disconnected from the EGR valve, so another interesting FYI, the LB works without EGR.
1998 Honda Civic HX - My Project Thread
The Following User Says Thank You to cbaber For This Useful Post:
1hondaman (01-07-2016)
