Old 03-21-2014, 12:47 AM   #144 (permalink)
TurnNBurn
You can see the tiny batteries I'm using at the bottom of two pictures. 12 volts each, about 7 ah. Only 3 of the 4 batteries work. But I got it rolling with 36 volts tonight. No throttle grip. I haven't wired up the controller yet.
So now I'm about to wire the throttle and controller just to test it out, but I want to use the same proper wire. Where to the gauges come in handy? I was thinking 3 ga wire for the controller/battery connections. Is that too much?
Also, I went to Lowes looking for some wire terminals for the throttle group. What terminal sizes will work with the Alltrax 7245? Am I even using the right terminology?
I did a test and hooked up the controller and throttle and I couldn't get it to work. No light on the Alltrax LED. I had it hooked up to a good 12v battery. Any ideas?
And a video of it running here:
https://www.dropbox.com/s/ys0cc58f1v...225557_575.mp4
I believe that's only 24v it's running on.
ID:	14780   Click image for larger version
ID:	14781   Click image for larger version
The Following User Says Thank You to TurnNBurn For This Useful Post:
ME_Andy (09-12-2014)
