Old 03-21-2014, 10:02 AM   #10 (permalink)
user removed
Originally Posted by johnlvs2run View Post
Thank you very much for the comments and tips. I will try coasting in neutral the next trip.
Compare the distance using neutral coasting versus DFCO. It will require greater distance anticipation to get the best benefit. When you have to slow down use DFCO, then brakes only when absolutely necessary.
regards
Mech
j12piprius (04-30-2014)
