how to smoothly shift back into gear from coasting in neutral (with engine running)
My interpretation of instuctions on another thread are as follows:
1) coasting in neutral / foot not on clutch;
2a) push clutch all the way in;
b) let the clutch out part way (to spin up the motor);
c) then press it back down;
3) shift into the appropriate gear;
4) touch the throttle to bring up the engine speed / to match the transmission speed?
5) then release the clutch.
I presume that re-engage in #5 of instructions means release.
Is this all correct?
