Originally Posted by 2000mc
Everything on the 3rd gens were narrower than the newer cars, so you just need to figure out how thick of a spacer you need. I had an iroc w/ different fr + r offsets I put 4th gen wheels on
On mine I had 2" spacers all the way around. Since swapping the 4th gen rear I only have the spacers on the front. Rear end came from a 1997 trans am with disc brakes.
![](http://ecomodder.com/forum/fe-graphs/sig8191a.png)
Fully sequential port fuel injection
406 sbc 350hp @4800 425lb-ft @3600
4L60e trans .70 OD, 3.23:1 rear, 26" dia. tire, 1,600rpm @55, 2,050rpm @70
