Old 01-05-2008, 01:59 AM   #15 (permalink)
trebuchet03
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by SVOboy View Post
Well, use a solenoid with a switch, just like a WVO conversion eh? Or even a temp switch that bypasses the exhaust portion at ~170.
Perhaps I should read up a bit more on the WVO heat exchangers (I've only seen coolant type exchangers - does an exhaust type exist?).....
I'm not trying to be completely negative - just pointing out what I think are obvious problems in thought.... Do you think there'd be a problem with the isolated coolant boiling off (in general, causing pressure issues)?
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
