Thats good.
Do you know the history of this motor? THe vw dieselis a heavy built motor.You put the rod against a rod from a 350 and its hard to tell the 2 apart.
With no adjustments you can floor the hell out of the engine and not have to worry about sending the pistons through the hood.
Same is true of the mercedes diesels as well.
