Old 03-24-2014, 12:35 AM   #12 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by RustyLugNut View Post
Anything older than 1975 is exempt from emissions in practically all areas.
Also, the ability to switch between a legal and a non legal setup should allow you to test in non Federal jurisdictions and continue to use the vehicle on Federal roads as you implied.
As you move along in your research, you may require a research exemption. But, that is usually for a period of time. You cannot drive your vehicle indefinitely on such an exemption.
How about moving the drivetrain into another vehicle?
Thanks RustyLugNut!!! This is what I'm going to do. In search of a pre 1975 car???
I have way to much time and $$$ invested in this to kill this thing.
Pressure Gradient Force
The Positive Side of the Number Line
