Originally Posted by Old Mechanic
I'm done when YOU stop making false statements about me, such as stating that I was the one who rebuilt the engine that had the piston failure, which is patently false and has no basis in fact. I asked politely that we just let it go, state our points without passing judgement and posting opinions that are presented as facts. Your choice, not mine.
Fact
You were posting information that had potentially catastrophic consequences for you. I advised you about the legal ramifications of YOUR actions. You come back with the insinuation that I was going to initiate a legal process by informing some fictitious person of authority who MIGHT pursue that legal situation.
Regardless of our adverse communications I have not, will not, and have no intention of ever engaging in that kind of action. While your vindictive response about what you considerred as a threat by me, when it was nothing more than advice that could have saved you a crapload of grief. That response was a pitiful attempt to make good advice, in fact, free legal counsel, something much more insidious that it ever was or would be.
I will respond to that kind of character assasination as long as you initiate it. The choice as to where we go, in that respect, on this forum or anywhere on the internet, is yours.
My goal is constructive imput and my wish to help people when I think that is possible. Yours, from the evidence you continue posting concerning your false conclusions that affect the perception of my character and integrity as percieved by those who read this forum and appreciate the uncompensated assistance they might recieve from a member with 60,000 hours of experience working on cars.
Maybe that attitude is so ingrained in your personna that it is unavoidable. Your best solution is to just pretend that my posts do not exist. Please put me on your ignore list. I would consider it as a favor.
Davo53209@yahoo.com
I'm very sorry for all the thread jacking.
I did not mean to personally attack Old Mech.
I thought Mech said he had a destroyed piston from someone else's build that Mech had to fix
I had a piston on my shop counter
. I didn't know he was the one who built the engine with the broken piston and piston ring. As fir me grammar and spelling sorry I'm trying to do my best.
I have had great luck with a ridge removal tool on certain types of engines with no engine failure. My point in my above post was on a Honda engine if there is any ridge... IMHO the block is done throw it away. Now on a engine like my 4G63 you could use a ridge removal tool and it would work for a low $$ build. Would it be the same if you were to bore the block absolutely not!!! But done right you could get another 100k out of it.
But back to you. If I were you I would do a leak down to see whats up??? You said its not using oil so the oil rings and valve guides and valve seals are doing their job. I would also do a compression test. This can show you things that the leak down can't and vice versa.
It sounds like the engine is down on power... correct??? Have you check to see if the timing is correct by finding TDC and checking it to the dist. and cam gear. Don't trust the crank pulley marks they have been known to move inside the hub. This happens a lot on the D-Series engines. There are some great write ups on this on D-Series.com.
Anyway good luck.
Mech,
You are very confusing?
So I was right in my first post. ^^^^^
You did not rebuild the engine that had the failure? My argument was in my experience in building engines, one can have great success using a ridge remover tool. As I already told you. So it looks to me that we disagree on a engine building procedure? That's cool with me
I'm not trying to get into a big toe measuring contest with you, but... I own and operate a very successful businesses!!! I build 1000+ HP 2.0L engine's for fun. I break a ton of parts doing so. Its part of the game pushing the envelope with BMEP numbers that even Nascar and F1 engineers can appreciate.
Your name should be "Old Lawyer" instead of "Old Mech" I would even hire you.
Mech,
chill out, this is just a car forum???
