Old 03-24-2014, 12:34 PM   #49 (permalink)
XYZ
Originally Posted by Baltothewolf View Post
Radiator fans don't kick on unless A/C is on. And yea grill block has been removed for a while.
Sounds like your primary cooling fan isn't coming on when it should. If both fans run when the A/C is on, it's not the fan itself that is the problem. It's either a sensor or a relay in the system that isn't turning the #1 fan on when needed.
