Old 03-24-2014, 01:39 PM   #46 (permalink)
Teri_TX
Hi JeffM,
Originally Posted by euromodder View Post
May I suggest a diagonal brace between the frame tubes underneath the rear saddle and the middle bulkhead ?
In the bottom picture, it looks like it's made to have a brace there, by continuing the frame tubes.
If I may suggest, using thin aluminum sheet or the door skins as you said for the skin will more than stiffen up the tail. Notice that monocoque airplanes generally don't have diagonal bracing between the hoop frames. You still will need to have some sort of brace to just hold up the tail.
Also, the "strringers" seem a bit beefy to me. Adding excessive weight, especially at the rear, isn't a good thing.
-- Teri
P.S. Not to toot my own horn but when you add a full front fairing, you may want to read my thread starting at: http://ecomodder.com/forum/showthrea...tml#post416335 Pete [Ironside] has "proven" that a stall strip can radically reduce side wind effects on a dust bin fairing.
