Old 03-26-2014, 06:48 PM   #42 (permalink)
Cobb
If you have no windows how are you going to vent the portable unit?
Well, I have a window unit and used carrage bolts that have flat smooth heads on the outside and made a sandwich of 2x4s inside and out to secure the unit and make it difficult to steal or break in. Its a 5000 watt unit and uses 300 watts.
If I had a garage attached or detached and it wasnt climate controlled Id see about adding a window unit even if i had to put it into the door.
Window units are magnets for thiefs plus there is no window in this garage.
