Originally Posted by Gealii
Agreed, when i take 35mph highway turns at 80 its fun, but when your rear end on a fwd slides out from under you it gets very fun
That is when you add more throttle and let the LSD dig you straight.
If you lift you will see where you were coming from.
Ecopia EP100's are very quiet in high slip angles
