Old 03-27-2014, 03:37 AM   #3 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The 6.2L diesel might be the obvious choice, but if you don't mind it being even more underpowered, try a VW 1.9L TDI engine. My friend and I towed a 1999 Forester with his 2002 Jetta TDI. The total weight must've been close to 7000 lbs. The TDI (stock other than nozzles) pulled the weight just fine. Hills were a bit slow. With the reduction in drivetrain weight, the Caprice/Roadmaster won't weight much more than a Jetta or Passat.
Other options are the Cummins 4BT and Mercedes OM617a.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
101Volts (03-27-2014)
