Old 03-27-2014, 10:27 AM   #5 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
1st Gen EPA ratings were far too optimistic.
I posted 27 and the current reading reads 26:
Fuel Economy of the 1985 Chevrolet Caprice Wagon
Originally Posted by Gasoline Fumes View Post
The 6.2L diesel might be the obvious choice, but if you don't mind it being even more underpowered, try a VW 1.9L TDI engine. My friend and I towed a 1999 Forester with his 2002 Jetta TDI. The total weight must've been close to 7000 lbs. The TDI (stock other than nozzles) pulled the weight just fine. Hills were a bit slow. With the reduction in drivetrain weight, the Caprice/Roadmaster won't weight much more than a Jetta or Passat.
Other options are the Cummins 4BT and Mercedes OM617a.
Thanks. I think I'll go with something powered higher though. And I didn't mention it in the topic but I am playing with the thought of using the car as a towing vehicle too.
Originally Posted by arcosine View Post
You could drop in an S-10 2.2L vortec I4 and 5 speed, 4200 lb gvrw. Whats the axle ratio in the wagon, 2.93?
1995*Chevrolet*S-10 Specifications
1995*Buick*Roadmaster Specifications/?acode=USA50BUC062D0
I'm talking about a 1996 model although I didn't specify that in the topic at first. Are there specs here relating to the ratio? (Also, I'd like something at least the size of a 5.0.)
SHAFT. Rear Axle Drive. 1996 Buick Estate # 26018080
