Old 03-27-2014, 06:52 PM   #7 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Gasoline Fumes View Post
The 6.2L diesel might be the obvious choice, but if you don't mind it being even more underpowered, try a VW 1.9L TDI engine.
With all the tuning options available, the 1.9TDI is not to be disconsidered. And it's not so underpowered at all, have been used even in some European vans slotted in a size between the Chevy Astro and the full-size ones.
Other options are the Cummins 4BT and Mercedes OM617a.
Trying to keep a 4BT under that hood wouldn't be the easiest job, but not impossible at all, and with lots of aftermarket support nowadays. If you would rather get a Mercedes-Benz engine, the OM603 might be a better option than the 617.
101Volts (03-27-2014)
