Old 03-28-2014, 04:42 PM   #83 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
Originally Posted by Mista Bone View Post
A) I will NOT give up any performance capabilities of the CRX in the name of better MPG, period.
Well, I'm gonna have to start calling you mista bone head then
The crx is a good foundation for efficiency (and no fear mongering from you!) best in the garage reports 68.45 mpg:
EcoModder Fleet list - EcoModder.com
With your comment about the longer gears and using less fuel. If the engine is turning more rpm, there fore in a more efficient rpm range, but using the same overall fuel per mile.
More rpm doesn't equate to more efficiency, need to understand the rpm/load bsfc charts for the engine in question. Very very roughly peak bsfc is around 2500 rpm @ 3/4 load in cars.
http://ecomodder.com/forum/showthrea...-got-1466.html
If you lower the rpm for a given power requirement (i.e. cruise), you have to open the throttle more, and there in lies a key advantage of lower rpm (but stay out of enrichment near full throttle).
I'm not lugging or having to downshift for the hills, aka "transient response" as some of the Honda Engineers called it.
Soooo... you are a "performance enthusiast", but shifting bothers you. I see...
