Originally Posted by EcoReality
But the neutral is grounded!
Having installed transfer switches, I can assure you, they do not break the neutral connection.
Also if you are going to get a transfer switch installed it may not be bad idea to have a single non-essential circuit excluded from the transfer so that you can see when the power comes back on. No need to run your batteries down more than is necessary.
