Old 03-29-2014, 11:51 AM   #588 (permalink)
NeilBlanchard
We have an easy going building department, last I checked. I'm going to keep it basic: 2x4 walls and I'll work out the ceiling and rafters in the section drawing. Probably CMU frost wall (similar to existing) and a slab, or possibly pavers for the floor. Long ago I dug a tranche and put in two conduits (3/4" and 1/2") with the intention of putting in a power circuit and a telephone/data wire. If I put some solar PV panels out there, I may need a second power circuit.
I'll have to check if I can also fit the Saab 900 in there (with the CNC and the work table(s) pushed to the corners). If it needs a little more room to get that in there, better change the plan!
I hope to eventually insulate it, and be able to extend the work year and the fiberglass 'season'. And the bicycles and yard tools etc. need to be stored, too.
aerohead (03-29-2014)
