Old 03-29-2014, 09:59 PM   #101 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Here's what I would like to discuss.
As you can see in this example BSFC map, the 25% load has a very tight vertical curve to it. So the sweet spot is much narrower then the 50% and 100% load lines.
Just moving up or down in rpm a little can take you away from the sweet spot.
At 2800 rpm you have the most efficient BSFC number of 0.70 lbs/hr.
At 2000 rpm you have 1.0 lbs/hr.
At 4000 rpm around 0.95 lbs/hr.
Food for thought???
Pressure Gradient Force
The Positive Side of the Number Line
