Old 03-30-2014, 02:18 PM   #21 (permalink)
Cobb
SMH....If your 37 ford operated at room temperature this would be great. Unfortunately that is when you develop the highest oil psi and as the vehicle warms up the oil psi drops.
Low oil psi at idle can be fixed in a number of ways. Heavier oil, high volume oil pump, replacing engine bearings or just increase the idle speed. You need to check the engine out from the bottom end to get an idea why you have low oil psi so you dont do something stupid and let the spinning parts loose.
PSI is just one aspect, you also need volume and quantity. Its not uncommon for most V block engines to pump oil to the top faster than it can drain back to the sump. This causes oil and air to get pumped into the system and its easy to spot on bearing shells.
Its also not uncommon to turn faster rpms of the rods that you sling the oil out faster than it can be pumped in for proper lubrication.
These are reasons alone why Bubba can floor his v 8 auto and have it instantly throw a rod.
Many engines have a pressure relief valve. Its basically a spring with a ball bearing inserted into one of the oil gallery. It helps to regulate oil psi by bleeding off excess psi. This can get stuck in the open position and cause a lost of lubrication as the rpms climb.
Furthermore many oil filters contain a bypass valve so you do not blow your oil filter if the psi is too high or if the filter is too clogged.
You ever consider adding a relay inline with an oil psi sensor so the ignition is not powered til oil psi is sensed? I want to say thats how my riding mower is setup. I tried to start it a few weeks ago to move something. IT cranked for 10 seconds and nothing happened. After 10 seconds it seem to suddenly crank faster, then it fired up. Im assuming the faster cranking ment oil had started to be pumped into the system and the low oil shut down decided to let me start up.
Originally Posted by Old Mechanic View Post
My original 37 Ford, with no oil filter and a 6 volt system, with a starter that cranked at 100 RPM, produced 60 PSI of oil pressur in 5 seconds if you pushed the starter button with the ignition switch in the off position.
regards
Mech
