The ecu will prevent you from wiping the oil film from the side o the cylinder during the compression stroke?
The ecu will prevent you from cooking your clutch? That maybe how he is doing 2200 rpms as its slipping.
Originally Posted by cbaber
The hazard of lugging is largely obsolete in modern engines with knock sensors and ECU controlled injection/ignition systems. 800 RPM in a Civic is fine, the problem is that there is no power, so there is no way you are maintaining speed on a hill. The real hazard in your situation is going 22 in a 50 ![EEK!](/forum/images/smilies/eek.gif)
