I am STILL waiting for Detroit, et.al., to start using the "ferro-magnetic-fluid" coupling torque-converter that they designed back in 1970-1980's...an off-shoot of the ferro-magnetic shock absorbers, which Corvettes use.
"Slips" like proverbial 'hot knife-thru-soft butter' when NOT energized, but "locks" as solid as a mechanical clutch when FULLY energized. But the "creme-de-la-creme" feature is the transitions are SMOOTH via computer control of the magnetic field(s): soft for OEM, medium for firmer shifts, and stiff for RACERS, etc..
