Originally Posted by MetroMPG
The last gauge I saw that would do this was the custom built SuperMID. Not sure if the MPGuino does it or not.
When I was using an MPGuino it would track distance traveled with engine off. If the key was on (vss signal getting to mpguino) the mpguino would stay active and count the distance traveled. It even had a field that would display distance traveled with no injector signal (Distance of EOC).
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
