Old 04-01-2014, 06:44 PM   #6388 (permalink)
64jeep
I took the old heater core out and run the water through there. I rigged up one of those big computer fans to blow air through it. I've got a picture here at the bottom.
Porsche 924 Electric Conversion: Batteries!
Being in AZ I was concerned about a fish tank pump not working at high temperatures, so I found a pump designed for solar panel cooling that's good up to 80 C. I got a friend with a CNC router to mill out all those channels. If you want to make one just like it, I have the CAD model that you could use to generate the tool path.
Electric Porsche 924 Converted using an IGBT based Paul and Sabrina Controller
electricporsche924.blogspot.com
The Following User Says Thank You to 64jeep For This Useful Post:
MPaulHolmes (04-01-2014)
