Old 04-01-2014, 06:30 PM   #6390 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
I used a random sequence generator based on atmospheric noise (so about as random as you can get) to spread the frequency from 6kHz to 10kHz. I found out that the dsPIC can change pwm frequency glitchlessly on the fly no problem, so I'm just going to do the spread spectrum switching. This will be the best of all worlds, except for when you want to put an oscilloscope on it. haha.
These are the maximum PWM duties:
RANDOM.ORG - Sequence Generator
EDIT: Oh crap, the averge period is 1/7.5kHz, since more time is spent on the low end. Now I've got to figure what some bounds should be such that 1/8KHz is the average period. Since I'm fixated on 8KHz. haha
EDIT AGAIN: OK, so max duties from 1600 up to 2400 give an exact average period of 1/8KHz. In terms of frequency, it's 10KHz down to 6666.666KHz.
kits and boards
