Originally Posted by MetroMPG
Old school drop! Cut-off wheel to remove a coil from each spring (assuming they're symmetrical).
(I accept and expect that I will be flamed for bringing up this tried & true Suzukiclone lowering method.)
Whoa, just saw this! Can you give more detail and/or is there a "build thread" for doing that? How much did it drop it, and do you have an estimate of the mpg improvement from that one mod? I've noticed the gnat is considerably higher than it "needs" to be.
Thanx,
Bill
