Old 04-02-2014, 10:26 PM   #302 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by t vago View Post
Thank you. It is a nice collaborative effort, and it's good to build off the already-capable original MPGuino code.
As for your questions, my code should run on the meelis hardware, as I am given to understand that the meelis hardware is a legacy MPGuino design. However, there appears to be no programming port on the meelis unit, as there is on the JBD unit.
meelis MPGuino - no programming port
JellyBeanDriver MPGuino - ISP programming port on other side of chip socket, opposite clock crystal (silvery) can
You would have to unsocket the AtMega integrated circuit on your meelis hardware, then mail it off to me so I could reprogram it. I am considering charging $5 to ship off pre-programmed AtMega ICs, as an alternative.
I'm guessing that soldering on the ISP port isn't an easy task on the legacy design? Might have to take you up on the preloaded AtMega...
