In my 2nd gen Insight I found it kept speeding beyond the set limit on downhills - in Eco mode and D, where the CVT maxes out the gear ratio.
The cruise control is very lax in Eco mode, much more aggressive when not.
I experimented with eco on and of, D with or without shifting paddles, S mode and even L mode downhills, but it was distracting. Flappy paddles are hopeless in hairpin corners.
Finally I stopped using CC in the mountains altogether and just keep it in D and brake or gas as needed. It will max out regeneration when breaking in any mode anyway.
About added drag by the hybrid system:
The hybrid systen in both Insight gens is nothing more than an electric motor doubling as a flywheel and an extra camshaft to lift the valves in DFCO/EV mode. The motor might cause some extra drag, but it doubles as an alternator (it has no separate 12V alternator) so that cancels out.
It cannot unhook the ICE completely like Toyota does with the HSD drive system, so it is less efficient in EV mode. No big deal as it is in ICE mode most of the time.
Sorry for the diversion... Back to the mighty Gnat?
