Old 04-03-2014, 02:48 PM   #314 (permalink)
modrcm
civic modrcm - '96 Honda Civic DX
Originally Posted by josemapiro View Post
When using these pins have to pin down the first in order to work.
these are the definition are used that I use for these pins.
Code:
// if the below "#define"s are commented out, code will compile for an AtMega328-series processor
#define ArduinoMega2560 true
//#define TinkerkitLCDmodule true
// if the below #define is commented out, 16 MHz system clock will be assumed
//#define use20MHz true // force 20 MHz system clock values
// only one of the below LCD options may be chosen - choosing more than one will cause a compilation error to occur
// if TinkerkitLCDmodule is used, useLegacyLCD will automatically be used, and the below options will be ignored
#define useLegacyLCD true
//#define useParallaxLCD true
// only one of the below button options may be chosen - choosing more than one will cause a compilation error to occur
#define useLegacyButtons true
//#define useAnalogMuxButtons true
//#define useParallax5PositionSwitch true
// the below options only work if useLegacyLCD is selected. If useLegacyLCD is not selected, the below options will not be inserted at all
//#define useLegacyLCDinvertedBrightness true	// For alternate LCD backlight connections
#define useLegacyLCDbuffered true				// Speed up LCD output
// selectable options - all may be chosen independently of one another, save for serial data logging.
// the serial data logging option will conflict with the Parallax LCD output option, if both are selected at the same time
#define blankScreenOnMessage true		// Completely blank display screen upon display of message
#define trackIdleEOCdata true			// Ability to track engine idling and EOC modes
//#define useSerialPortDataLogging true	// Ability to output 5 basic parameters to a data logger or SD card
//#define useBufferedSerialPort true		// Speed up serial output
//#define useCalculatedFuelFactor true	// Ability to calculate that pesky us/gal (or L) factor from easily available published fuel injector data
#define useWindowFilter true			// Smooths out "jumpy" instant FE figures that are caused by modern OBDII engine computers
#define useClock true					// System clock, and means to set it
#define useSavedTrips true				// Ability to save current or tank trips to any one of 10 different trip slots in EEPROM
#define useScreenEditor true			// Ability to change any of 8 existing trip data screens, with 4 configurable figures on each screen
#define useBarFuelEconVsTime true		// Show Fuel Economy over Time bar graph
#define useBarFuelEconVsSpeed true		// Show Fuel Economy vs Speed, Fuel Used vs Speed bar graphs
#define useSpiffyBigChars true
//#define useChryslerMAPCorrection true	// Ability to perform on-the-fly fuel injector data correction for late-model Chrysler vehicles
//#define useABresultViewer true			// Ability to graphically show current (B) versus stored (A) fuel consumption rates
//#define useCoastDownCalculator true		// Ability to calculate C(rr) and C(d) from coastdown
// program measurement and debugging tools
//#define useDebugReadings true
//#define forceEEPROMsettingsInit true
//#define useEEPROMviewer true			// Ability to directly examine EEPROM
//#define useBenchMark true				// this is probably broken - last time I used it was in August
//#define useSerialDebugOutput true
Take a picture and put the links here.
These define me neither works, you Might be kind enough to explain the connection of the cables (not that the screen is correct mine) and spend the program?
I have enclosed a picture of my plate
Thank you very much to the two, to see if I can make it work
Free File Sharing and Storage made Simple.
The Following User Says Thank You to modrcm For This Useful Post:
josemapiro (04-03-2014)
