Old 04-03-2014, 04:01 PM   #316 (permalink)
josemapiro
Originally Posted by modrcm View Post
These define me neither works, you Might be kind enough to explain the connection of the cables (not that the screen is correct mine) and spend the program?
I have enclosed a picture of my plate
Thank you very much to the two, to see if I can make it work
Free File Sharing and Storage made Simple.
If you use the A11, A12 and A13 pins with the definition I'm using has to work.
With the option of using an wire, was watching the image and I think it has an error with the white wire that connects the R1 resistance along with the yellow, he has to start after the resistance and not to 5V.
as my english is bad also let in Portuguese is similar to Spanish
Se utilizar os pinos A11, A12 e A13 com as definições que estou a utilizar tem que funcionar.
Com a opção de um fio usando as resistências, estive a ver as imagem e creio que tem um erro com o fio branco, que liga a resistência R1 juntamente com o amarelo, ele tem que ligar depois da resistência e não aos 5V.
