Old 04-03-2014, 05:15 PM   #317 (permalink)
modrcm
civic modrcm - '96 Honda Civic DX
Originally Posted by josemapiro View Post
If you use the A11, A12 and A13 pins with the definition I'm using has to work.
With the option of using an wire, was watching the image and I think it has an error with the white wire that connects the R1 resistance along with the yellow, he has to start after the resistance and not to 5V.
as my english is bad also let in Portuguese is similar to Spanish
Se utilizar os pinos A11, A12 e A13 com as definições que estou a utilizar tem que funcionar.
Com a opção de um fio usando as resistências, estive a ver as imagem e creio que tem um erro com o fio branco, que liga a resistência R1 juntamente com o amarelo, ele tem que ligar depois da resistência e não aos 5V.
Thank you very much, the right side was testing the multiplex buttons, but then decided to use the 3 buttons, left to A11, A12 center and the right button to A13, but does not work, nor defined yours, nor mine.
Connect those wires: Pin - push - GND
