Old 04-03-2014, 04:42 PM   #318 (permalink)
josemapiro
Originally Posted by modrcm View Post
Thank you very much, the right side was testing the multiplex buttons, but then decided to use the 3 buttons, left to A11, A12 center and the right button to A13, but does not work, nor defined yours, nor mine.
Connect those wires: Pin - push - GND
I'm using the Arduino Mega with the A11, A12 and A13 pin and it has worked flawlessly, not to function may have a fault on the board. Seeks to create a simple program just to test the pins.
The other system with the resistances, I'm not using now, but I've also tested it before and it worked.
Eu estou a utilizar o arduino mega com os pinos A11, A12 e A13 e tem funcionado sem falhas, para não lhe funcionar pode ter alguma avaria na placa. Procure criar um programa simples só para testar os pinos.
O outro sistema com as resistencias, não o estou a utilizar agora, mas já testei antes e tambem funcionou.
