Old 04-03-2014, 10:21 PM   #1052 (permalink)
CrazyLee
The Beast - '93 Fleetwood Flair includes kitchen sink
90 day: 9.2 mpg (US)
The Bigger Beast - '03 Winnebago Sightseer Motor Home
Originally Posted by 2003protege View Post
So if you apply 75%+ throttle, the display instantly pegs at 999? Sounds like your throttle % is affecting the MPG calculation, not necessarily that it "quit" but that the calculation is picking up the throttle. I'm wondering if there isnt' a wiring problem.
It is kinda hard to pick on the throttle. All it does is add more air to the engine. The ECU tells the injectors to fire longer. The rev counter in the ECU tells the injectors to fire more often.
The 'Guino sees faster vss and faster, longer injector pulses.
The MPGuino calculates fuel used from those 2 parameters.
The only thing that may be the culprit is this below. I think I have it set to 500.
Injector DelayuS - Represents the mechanical delay of the injector in microseconds. Advanced topic.
I will try and reduce the number, maybe to 250 and see what happens.
My theory is the code trips up on the bigger number. Maybe I'm thinking backwards.
I'll try it soon.
