Old 04-04-2014, 10:54 AM   #319 (permalink)
modrcm
civic modrcm - '96 Honda Civic DX
Originally Posted by josemapiro View Post
I'm using the Arduino Mega with the A11, A12 and A13 pin and it has worked flawlessly, not to function may have a fault on the board. Seeks to create a simple program just to test the pins.
The other system with the resistances, I'm not using now, but I've also tested it before and it worked.
Eu estou a utilizar o arduino mega com os pinos A11, A12 e A13 e tem funcionado sem falhas, para não lhe funcionar pode ter alguma avaria na placa. Procure criar um programa simples só para testar os pinos.
O outro sistema com as resistencias, não o estou a utilizar agora, mas já testei antes e tambem funcionou.
I tried doing a small program to turn on a LED with buttons and working properly: S
have seen a very well this?
Code:
#ifdef TinkerkitLCDmodule
const uint8_t vssBit = 				(1 << PINB1);
#else
const uint8_t vssBit = 				(1 << PINC0);
#endif
#ifdef useLegacyButtons
#ifdef ArduinoMega2560
const uint8_t lbuttonBit = 			(1 << PINK3);
const uint8_t mbuttonBit = 			(1 << PINK4);
const uint8_t rbuttonBit = 			(1 << PINK5);
const uint8_t longButtonBit = 		(1 << PINK6); // PINK6 isn't being used for anything right now
#else
const uint8_t lbuttonBit = 			(1 << PINC3);
const uint8_t mbuttonBit = 			(1 << PINC4);
const uint8_t rbuttonBit = 			(1 << PINC5);
const uint8_t longButtonBit = 		(1 << PINC6); // PINC6 is used as the RESET pin, so this value is safe to use for long-press signalling
#endif
