Old 04-04-2014, 12:22 PM   #23 (permalink)
E.Roy
fuel conserver
Civic - '99 Honda Civic EX
Originally Posted by johnlvs2run View Post
My interpretation of instuctions on another thread are as follows:
1) coasting in neutral / foot not on clutch/ engine running;
2a) push clutch all the way in;
b & c not needed, slows car down too much:
b) let the clutch out part way (to spin up the motor);
c) then press it back down;
3) touch the throttle to bring up the engine speed / to match the transmission speed?
(switched order of 3 & 4)
4) shift into the appropriate gear;
5) then release the clutch.
I presume that re-engage in #5 of instructions means release.
Is this all correct?
Fixed your order (in bold)
It is called heel toe downshifting in racing, because you are never coasting while racing. But I use it even if I am just driving on the streets for downshifting and in coasting situations. It really helps in finding 1st gear as you come up to a stop, and helps your synchros last longer!
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
The Following User Says Thank You to E.Roy For This Useful Post:
j12piprius (11-01-2014)
