Thanks much for the detailed comments and interesting videos.
I'm fine shifting from gear to gear. The issue arises after coasting down in neutral, then shifting back into 5th, for example coasting in neutral from 65 to 50, then going back into 5th, so my question is only about shifting from coasting in neutral, back into 5th.
Based on the comments and videos, I need to press & release (blip) the gas, then clutch, then gas. In other words the gas is pressed down, then quickly released as the clutch is pressed, which is then quickly released as the gas is pressed back to 5th gear position.
I want to review and practice these things, then will post back with results.
