Yea that sounds right. Basically if you're watching the tach, what you do is stomp the gas, press the clutch in and release gas together and the moment it's all the way down you put the shifter in gear, and hopefully the engine was at the right rpm, it'll go over a little, and then by the time you release the clutch it hopefully would've dropped back down to the correct rpm again.
