Old 04-05-2014, 10:32 PM   #28 (permalink)
Occasionally6
Originally Posted by johnlvs2run View Post
I'm fine shifting from gear to gear. The issue arises after coasting down in neutral, then shifting back into 5th, for example coasting in neutral from 65 to 50, then going back into 5th, so my question is only about shifting from coasting in neutral, back into 5th.
It blurs into gear shifting because what you are doing is effectively half of a gear shift. The same techniques apply.
Based on the comments and videos, I need to press & release (blip) the gas, then clutch, then gas. In other words the gas is pressed down, then quickly released as the clutch is pressed, which is then quickly released as the gas is pressed back to 5th gear position.
Don't lose sight of the end which is to match the engine, gear and shaft speeds.
