Old 04-06-2014, 06:33 PM   #4 (permalink)
cRiPpLe_rOoStEr
Originally Posted by autoarcheologist View Post
Lowering it - partly for handling, also for FE. I already have the kit, just need to find the time!
We rarely use 4WD, and frankly would ditch it, except occasionally we need it to back into a tricky camping spot. Like tonight, uphill on gravel, we wouldn't have made it without 4WD. Otherwise we run in 2WD.
Which kit are you going to use for lowering it? Have you never considered an adjustable suspension setup?
Regarding 4WD vs. 2WD: are you sure a selective differential locker wouldn't provide the traction control required under those conditions?
