It looks like a double sided card is a no go at Staples. You'll need to condense it into one image. It needs to be 1050 X 600 pixels to be the optimal size to fit everything.
Document Trim Size (final size after being cut)
3.50" x 2.00"
89 x 51 mm
1050 x 600 pixels
* Please be sure to keep all text within the safe margin.
Resolution
300 DPI
My layout idea is: Use second image as the base,
Aerohead truck,---"Hypermiling tips text,"--- Basjoos car,
1-----------------------------6
2-----------------------------7,
3-----------------------------,
4-----------------------------,
5-----------------------------8
QR code---Ecomodder Logo.
Text is (feel free to edit as you see fit):
Hypermiling tips:
increase your fuel economy
and beat the EPA ratings!
1, Drive less, Drive smart.
2, Combine errands and Carpool.
3, Keep tires properly inflated.
4, Reduce your speed.
5, Remove junk from your trunk!
6, Remove roof rack when not in use.
7, Drive with load:
lose speed uphill,
Gain speed downhill.
8, Anticipate traffic and red lights.
I try to be helpful. I'm not an expert.
