When you get done with the front, then you can look at the all important back.
http://ecomodder.com/forum/showthrea...ell-15862.html
FYI: below is the design I mentioned earlier ( deflection plate).
http://ecomodder.com/forum/showthrea...red-27976.html
From that thread ( not confirmed - just reposting)
Originally Posted by chefdave
strangley enough the bull bars are known for decreasing front drag. i picked up 1-mpg or 6.5% improvement. also the angle of the board defects air upwards and leaves a dead spot of air on bonnet ..........
