Old 04-08-2014, 10:38 AM   #14 (permalink)
k-vette
Yotarolla - '06 Toyota Corolla ce
90 day: 45.15 mpg (US)
Nighthawk - '84 Honda 700s
Motorcycle
90 day: 56.23 mpg (US)
Wife's Camry - '10 Toyota Camry
90 day: 23.89 mpg (US)
Vortex Energy Recovery - Innopedia
I'm trying to determine a couple of things. 1. Is a drag causing vortex really an issue at this speed?
2. If I built the design as is, how would I test the existing vortex, then eliminate it?
The picture above answers part of the question. I could mount a small turbine and let it spin freely to see the effect of the vortex. I could then make small adjustments to the body to improve it. If the vortex generated seems insignificant, then I won't even mess with it. I've been studying Wingfield of aircraft since they're the same shape and have tips specifically designed to eliminate this problem.
I also learned that the vortex created is inversely proportional to the aspect ratio.
The Following User Says Thank You to k-vette For This Useful Post:
freebeard (04-08-2014)
