Old 04-08-2014, 01:31 PM   #11 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by xntrx View Post
Should check the Cadi and Pontiac versions of the same era. Many had skirt that could be adapted. This would give an OEM solution and look that could be built upon.
I wonder how hard it would be to swap the back glass to the aero coupe style?
Fyi, the 6.2 diesel is a fairly easy swap (bolts in, but normal diesel conversion stuff like brakes, tank...).
So are the Pontiac Parisienne and Cadillac Coupe De Ville models what you're referring to?
Here's a photo of a 1986 Pontiac Parisienne with wheel skirts:
Maybe I can find some in decent shape in a junkyard.
And, What's involved in putting an aerodynamic glass on the back end? I'm aware the trunk will need to be shortened in such a modification.
As for the Diesel, Just for reference I realize you're talking about another motor and not the 5.7 that some of these G.M cars came with. An engine swap is definitely a possibility, But for now I'll use the stock motor. The car is close to 110k miles as is, I think I'd be able to get 23+ HWY if I stuck the right Diesel motor in though. And, I'm probably not going to tow anything with this car and it doesn't have a stock hitch.
Originally Posted by slownugly View Post
Hard to say how much a trans swap would be worth. It would def show an improvement
Thanks.
