Old 04-08-2014, 09:24 PM   #6 (permalink)
Mustang Dave
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Thanks, Mark.
Yeah, get instrumentation. ScanGauge or UltraGauge to show instantaneous MPG, % load, engine temp, open/closed loop, et cetera. It WILL make a difference if you use it.
Originally Posted by Gas View Post
... Is driving without brakes basically just coasting it to neutral and just letting momentum do its job?
No. That's engine-on coasting. I actually do very little neutral coasting. Coasting downhill in neutral is illegal in Arizona. ARS 28-895.
Read this ecomodder blog post for more information about DWB. I also downshift and engine brake (using Deceleration Fuel Cut Off) to avoid using the friction brakes.
I can drive down the road from my local ski area with my F-250 to the highway without touching the brake pedal until I have to stop at the bottom. This road has an average grade of 6% with some tight turns that can only be taken at 35 MPH. Posted speed limit is 30. Since I started DWB with my truck, the MPG has improved noticeably.
I also use cruise control extensively, and use the acc/dec buttons at speed limit changes.
Many hypermilers will tell you that cruise control and engine braking/DFCO are the wrong way to do it, but at 48.75% over EPA combined (lifetime average, and currently climbing), my technique doesn't seem to be COMPLETELY wrong.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
The Following User Says Thank You to Mustang Dave For This Useful Post:
Gas (04-08-2014)
