Originally Posted by P-hack
Ah, I was meaning that anyone can build/modify/compile firmware for one for personal use without much concern (indeed there are clones).
That's MS-2 then, 2005 design. It is 2014 here in Chicago.
MS-2: 24 MHz, 4 kB
rusEfi: 168MHz, 192kB
While you can run an engine even on 8MHz, the extra speed and RAM makes the source code much easier to modify & extend, it's just a different level of comfort for software developers.
