Old 04-09-2014, 08:44 AM   #1 (permalink)
pete c
Does DFCO truely cut off the fuel?
I thought it did, but, got into a debate with some guy who appeared to be quite knowledgable about the subject, that this is not the case.
This took place on a hyundai forum where I went asking about wiring a FI cutoff switch. After the obligatory scolding from the anti-hypermiling crowd, this guy said that the injectors do still fire, but the pulse is much shorter. I argued that a hyper lean condition would result and that ain't good for the engine. He said that hyper lean is not an issue at such a small load.
I can see how this might be done just to keep the cat hot.
What say you ECU gurus out there? Is DFCO truely DFCO?
The Following User Says Thank You to pete c For This Useful Post:
California98Civic (04-09-2014)
