Old 04-10-2014, 09:04 AM   #6445 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Originally Posted by Astro View Post
For the housing. Maybe add some through connects similar to what Curtis has on their controllers. Have the copper buses bend upwards at the end and so that they are vertical and in line with the ends so the through connects can screw one side directly to the bus and the outside have a stud to connect the lugged cables from the motor/batteries.That way you could use metal ends and screw it down making it weather proof and not have to mess about with plastic ends?
Is there a need for air flow or does the heat sink suffice?
I'm having trouble picturing this. Metal end caps? How would you isolate the bus from them?
kits and boards
