37% at 800RPM? wow, i assume fuel pressure is dependant upon RPM? if so, that would require injector flowrate compensation based on RPM.
the VSS buffer(DRAC): the signal that goes to the cluster SHOULD be a 4000PPM signal, pin C15, should be blue with a back stripe according to my diagrams.
